Another plugin to share, this time something that tracks any unread emails in a Gmail account, based on a particular label (both custom and default multiple labels can be scanned).
Once installed and configured, it will periodically check to see if a particular message has had a label assigned, and if so, it will let you know how many you have. A use-case would be if you’re waiting for something specific to arrive, such as notification email from a system, then you could use this to keep checking and then to make you aware..
https://github.com/nodecentral/Luup-GMail-ATOM-Sensor
As it can be set up to scan all default labels too, it’s a great content provider for Reactor..
Here’s a quick screenshot too..
In the above example, it’s letting me know that there is an unread email assigned to my Vera/ezlo label..
As always, these are created based on my level of skill, so they are not perfect, but they should work and are something to have fun with ![]()
