What’s the difference between luup and lua?
Why is there a luup code box with each trigger and one for the entire scene? Can the scene be aborted from a luup code in the trigger’s luup box and does the luup code in the other luup box only run if the scene is not already aborted due to a code in the trigger box?
Thanks,
Lua is a programming language (with a capital “L”). Luup is a Lua module that implements extensions to suit and to give access to the MIOS environment - the Luup “engine”. Presumably Luup is a contraction of “LuaUPnP”, which in turn is just a combination of Lua and UPnP.
http://wiki.micasaverde.com/index.php/Luup_Lua_extensions
On the rest, have a look at the diagram on this page:
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events
The explanation above is correct and below is the additional reference.
http://wiki.micasaverde.com/index.php/Luup_Intro
Can you break your questions down a bit as it just got a little lost when I first read it. I will try to answer as best I can.
The luup box is a UI design and each scene can implement an action or not activate an action based on the code. I not sure where you are seeing the luup code within the trigger.
A trigger is a single event that result in the action being performed or adversely not continuing. E.g start and stop.
Have a read here:
http://forum.micasaverde.com/index.php?topic=11818.0
[quote=“a-lurker, post:2, topic:177632”]On the rest, have a look at the diagram on this page:
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events[/quote]
I have looked at this diagram dozens of times before without noticing the answer to this question. Now I see it! Thank you so much
