I was programming several PLEGs on my system and suddenly this popped up and now my Vera is acting unpredictably.
I found this thread and attempted the solution without success
[url=http://forum.micasaverde.com/index.php/topic,47790.0.html]http://forum.micasaverde.com/index.php/topic,47790.0.html[/url]
The Error is my ‘Cellular Events’ PLEG
I attached some screen shots and just turned on the Debug.
I will attach when I have it filled up a bit.
Let me know if there is anything else you need.
Thank you
Logic Report
I am trying to print out a log. I just get a black window popup with only the Date and Time on it.
You will need to look in the Vera log file while you reload Vera to see what errors it is encountering during startup.
Thank you Richard for responding during the holidays.
I rebooted the Vera Plus and then captured the log.
See attached Part 1
I am travelling and do not have access to source code …
Looks like something was corrupted.
You might want to restore your Vera from a backup before the problem happened.
Crap… There goes hours of programming…
Bad timing for me to have this happen during the holidays.
I made a back up before attempting to restore in case you, or someone else, can find an easy fix.
I am not sure what time I started to see the issues so I will need to try a few different restore points.
Happy holidays and thank you for responding while traveling.
Jim
If you did your programming in PLEG … you can make backups for each of your PLEG.
Then when you get things working again … restore your PLEG backup.
