I just logged in to Vera.com and clicked Luup Events and it says no devices. It use to have 2 devices in each room. I don’t know if this happened after reverting from UI3 but I need this function to work to montior my vacation rentals door locks. My other Vera that I never messed with still works fine. Did this happen to anyone else? Is it related to UI3 reversion?
can you elaborate?
After logging in to findvera.com then clicking on Luup Events I used to be able to click on the lock and see when someone opened the door what code they used and when it was locked. Now the devices don’t show up on there. These are logs that are stored online so all the old info that was stored for months is gone too.
Here’s a screen shot of the bad one.
Here’s one of my other Vera that still works.
My guess, you are probably suffering from the “synchronization” issue, mentioned in one of the threads - cj said it’s because when you downgrade from UI3 back to UI2, you have to rebuild/restore your network and the info on findvera is not in sync with your Vera…
Well that sounds like the kind of disappointment I’m use to. So much for the whole UI2, 3 ,4 all having the same back end and only what you see is different and it won’t change the functionality which ever UI you use speach.
Quote from MCV “In Vera, the back-end engine, which is the brains that does all the work, is completely separate from the user interface, and does not ever change. So, while UI4 is in developement, users will be able to choose between UI2, UI3 or UI4 knowing that the engine and core functionality are the same and just as stable.”
