Found this in another thread which was a few days ago.
The latest backup i manually took, i think was when i was experiencing the issue.
Will that cause an issue restoring it? or do i have to go further back?
Found the same thing after updating to the latest FW. Now I cannot access the VeraLit at all anymore. Something is drastically wrong.
It says, “Error no relay found” return to page.
I resolved my issue and had it confirmed by the support chap on the phone this is what he would have done for my issue:
The commands that I used once I logged in the the Edge by ssh were:
cd /etc/cmh
Stop_cmh.sh
mv user_data.json.lzo user_data.json.lzo.bak
mv user_data.json.lzo.5 user_data.json.lzo
Start_cmh.sh
When I replaced the current user_data.json.lzo file with the oldest backup of this file and restarted cmh everything worked again.
Now HWVE, mine was a vera edge which was able to be accessed from outside the network slightly different than your error.
Did you take a backup prior to the fw update?
can you not restore that?
Thanks for your reply. I always make a backup prior to updating the FW. However, when I went and looked at the VeraLite, I saw that not all LED’s were lit. So I did a reboot by unplugging/plugging the vera and all went back to normal.
