I used this string to play a wave file from the PC, depending on who unlocks the door(unique entry codes). This worked when I added it to the luup tab of a scene:
os.execute(‘curl -g “http://192.168.1.110:8080/requests/status.xml?command=in_play&input=file:///C:/HomeVoice/welcomehome.wav”’)
The problem (besides me being confused by lua code) is that the wave file plays before the door is open and I want to add a 5 second delay. I tried using a delay in the scene, but I only have the option to delay device functions. The next thing I tried was saving the above code as welcomehome.xml and uploading it to luup files under apps.
I then used the below code on the luup tab of the scene:
luup.call_delay (“welcomehome”,5)
This results in no sound at all. Am I using the uploaded luup wrong or is something wrong with the way I’m calling it up from the scene? Any help is appreciated. I may not have been searching efficiently, but I have searched this for 2 days on vera and lua forums.
thanks,
Rick
