Lutron RadioRA2 App
Maybe it’s just me… it is late. I installed the Lutron RadioRA2 app and there’s no username/password box anywhere to be found. There used to be…I was running this app on this box just a few weeks ago. Maybe I’m just too tired for this…
Nobody?
I installed on my other Vera Plus box and still there’s no username/password field anymore. Is the app now broken or did the latest updates kill it?
I do not have the device nor installed the plug-in. Is there a variable in advanced settings of the device to place the username/password?
There used to be!!!
I installed it now on 2 vera plus units that I have and neither of them are showing the username/password entry fields that are needed to connect to the Lutron box via telnet. The textbox for IP is still there so are the rest of them, but the username/password boxes are gone!!!
All of the Lutron bridges that support telnet integration use a HARDCODED username/password.
Neither the username nor password can be changed.
There is no need for a username/password entry box, and the RadioRA2 plugin does not have them.
[quote=“cybrmage, post:5, topic:199266”]All of the Lutron bridges that support telnet integration use a HARDCODED username/password.
There is no need for a username/password entry box, and the RadioRA2 plugin does not have them.[/quote]
There used to be a field in the app, now there isn’t and it’s not connecting to my bridge.
That may be the case but the PLUGIN requires the credentials to work and the fields to input them are missing. Now granted it would make sense if the credentials can’t be changed to just hard code them.
luup_log:6: (Lutron RA2 Gateway PLugin)::(getInfo) : ERROR : Username or Password field cannot be blank or default! <0x76ed7520>
same problem here - anyone figure this out. Vera is not pulling any of my RA2 devices or config… I am guessing its because it can’t log in without a password or username
anyone figure this out. I am about to toss this thing and move on.
Vera support was ok but took their sweet time in getting this work around in place. There’s no official fix or resolution and the statement is a “bug has been filed” with no ETA on resolution. This is a Vera created app and a Vera created problem and they just don’t seem to care. For those suffering there’s the temp fix for it until Vera breaks it again
luup.attr_set(“username”,“lutron”,xx)
luup.attr_set(“password”,“integration”,xx)
–replace xx with the device ID of the Lutron plugin
Enter that as luup test code in apps → develop.
