Lutron Caseta Smart bridge
Is there a Lutron Caseta plug in for Vera?
As I understand it Caseta Smart Bridge does not allow the Pico remote to control a Power Pack
I was hopping my Vera Plus could control the Caseta Smart Bridge.
And if so would it be able then to control a Lutron power pack?
thanks,
If you have a Caseta Pro bridge you can use the RadioRA2 plugin. If not you’re out of luck.
Yes have a Caseta Pro Bridge.
The RadioRA2 plugin will control a Lutron power pack then?
The Caseta system doesn’t allow the Pico remote to control the Lutron power packs.
again thank!
[quote=“jerrywolfer, post:3, topic:199719”]Yes have a Caseta Pro Bridge.
again thank![/quote]
PowerPak’s are only controllable by actual RadioRA and HomeWorks controllers. No Caseta controller or RA Select will control the PowerPak modules.
Thanks for the great help.
I had hopped I could use the Vera+ as a back door.
Once I loaded the RRA2 plug in couldn’t find anyway to add a power pack anyway.
Or for that matter any other Caseta device hi hi
again, thanks
