Appreciate in advance any assistance - I’m trying to set up a Lutron Caseta Smart Bridge Pro 2 (L‑BDGPRO2‑WH) with my VeraPlus system.
I’ve installed the Caseta system successfully:
– Smart Bridge Pro 2 installed and operational
– Lutron app downloaded to my iOS iPhone, and communicates properly with the Caseta hub
– 1 device (a Caseta switch) connected and working properly
– Telnet support activated on the Lutron app (Settings, Advanced, Integration)
– Integration report generated via the Lutron app
I’ve installed the Lutron RadioRA2 Gateway plug-in on my VeraPlus:
– Plugin located via Apps (app ID 5096, v1.4)
– Install is in “My apps” on my VeraPlus
– The app created device “#53 Lutron RadioRA Gate”
– I’ve updated the device configuration in the Vera Params tab with the IP address, MAC address, username “lutron”, and password “integration”
What next? What I want to do is to be able to control the Caseta switch (simple on / off) via my Vera system, both via the Vera UI and via scenes. The Caseta device ID for the switch is “2”. What else do I need to to set up the plug-in? I can’t figure out what I’m missing …
Thanks. James
