Luaxp expression
I’m trying to store&manipulate SiteSensor’s results in Reactor expressions/variables and essentially trying the following code:
local result = getstate( 310,"urn:toggledbits-com:serviceId:SiteSensor1", "FailedSince" )
if (result == nil) then
  -- nothing
else
  strftime("%X %x", result)
I might be obvious why this fails, but what would be the best way to achieve this in Reactor?
Note:
  1. LuaXP expressions are not Lua.
  2. Take a look at the if() function. That’s one of two quick ways to do what your code does in one step/expression.
Reference:
thanks again, used solution below:
if ( getstate( 310,"urn:toggledbits-com:serviceId:SiteSensor1", "FailedSince" ) != nil, strftime("%X %x", getstate( 310,"urn:toggledbits-com:serviceId:SiteSensor1", "FailedSince" ) ) )
