LuaUPnP process crashing all the time - feature or bug?
Seems like just about every time I save a change via the UI, the process restarts. Looks like it’s catching an ABRT signal.
Is this how it’s supposed to work?
Edit: even clicking the Reload button on the UI causes a crash. Every single time.
[quote=“scholvin, post:1, topic:174699”]Seems like just about every time I save a change via the UI, the process restarts. Looks like it’s catching an ABRT signal.
Edit: even clicking the Reload button on the UI causes a crash. Every single time.[/quote]
Clicking the Reload button causes the Luup process to restart - this is what the reload button does…
Chris
The problem with computes is they always do exactly what you tell them to do AND they rarely do exactly what you want them to do!
Interesting design choice.
Thanks for the info.
I suspect it’s necessary to do it this way in order to get all the plugins to reload under the Lua environment. It would be nice if a single plugin could be reloaded, but I suspect that the Lua system may not allow that even if MCV wanted to…
Chris
