Hi everyone,
So last night all hell (sorry for my language) broke loose.
I have a Vera Light running the newest firmware.
The unit was running absolutely fine until last night.
Problem:
Whenever I run a scene or turn a light on or off the LuaUPnP crashes, then restarts. The yellow light on the Vera also turns off, then comes back on after 20 seconds. The termination code is 137. This started happening at 10/05/12 at approx 7:30pm. I did not make any changes to the unit before this happened, the unit was running fine. Whenever I run scenes (turn all light on, off, dimm all lights) this happenes. On the dashboard I get strange message as well when I turn off lights etc. It says: waiting for ack, then freezes and the LuaUPnP Engine restarts again ![]()
This is from the logs:
05/10/12 19:36:04.013 Dumping 17 locks <0x2b7d7680>
02 05/10/12 19:36:04.013 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.014 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.015 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.015 finished check for exceptions <0x2b7d7680>5/10/12 Log for device LuaUPnP
192.168.1.201/cgi-bin/cmh/log.sh?Device=LuaUPnP 3/20
02 05/10/12 19:36:04.015 OL: (0xb01d84) (>2158) ThreadedClass …/JobHandler/JobHandler.cpp l:394 time: 4:00:00p (1336703764 s) thread: 0x2b0a3000 Rel: Y Got: Y
02 05/10/12 19:36:04.016 OL: (0xcf7ce4) (>2352) Lua LuaInterface.cpp l:1739 time: DL7:34:52p (72 s) thread: 0x2b9d7680 Rel: N Got: Y
02 05/10/12 19:36:04.016 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.016 OL: (0xc63a6c) (>2871) ThreadedClass …/JobHandler/JobHandler.cpp l:394 time: 4:00:00p (1336703764 s) thread: 0x2bbd7680 Rel: Y Got: Y
02 05/10/12 19:36:04.017 OL: (0xc63a6c) (>2876) ThreadedClass …/ZWave/ZWaveJobHandler.cpp l:777 time: DL7:35:04p (60 s) thread: 0x2b7d7680 Rel: N Got: Y
02 05/10/12 19:36:04.017 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.017 OL: (0xb01df4) (>2882) Variable Device_Basic.cpp l:446 time: 7:35:04p (60 s) thread: 0x2b7d7680 Rel: Y Got: Y
02 05/10/12 19:36:04.018 OL: (0xb01df4) (>2888) Variable Device_Basic.cpp l:446 time: 7:35:04p (60 s) thread: 0x2b7d7680 Rel: Y Got: Y
02 05/10/12 19:36:04.018 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.018 OL: (0xcf7ce4) (>2890) Lua LuaInterface.cpp l:1980 time: 7:35:04p (60 s) thread: 0x2b7d7680 Rel: N Got: N <0x2b7d7680>
02 05/10/12 19:36:04.019 OL: (0xb01df4) (>3153) Variable JobHandler_LuaUPnP.cpp l:6709 time: 4:00:00p (1336703764 s) thread: 0x2e1d7680 Rel: Y Got: Y
02 05/10/12 19:36:04.019 finished check for exceptions <0x2b7d7680>
02 05/10/12 19:36:04.019 OL: (0xb01df4) (>3278) Variable JobHandler_LuaUPnP.cpp l:6709 time: 4:00:00p (1336703764 s) thread: 0x2dbd7680 Rel: Y Got: Y
01 05/10/12 19:36:04.019 Deadlock problem. going to reload and quit <0x2b7d7680>
03 05/10/12 19:36:04.020 JobHandler_LuaUPnP::Reload: deadlock Critical 1 m_bCriticalOnly 0 dirty data 1 <0x2b7d7680>
01 05/10/12 19:36:11.194 Main WatchDogRoutine: blocked - terminating 1 <0x2e3d7680>
02 05/10/12 19:36:11.196 Dumping 16 locks <0x2e3d7680>
02 05/10/12 19:36:11.196 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.197 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.198 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.199 OL: (0xb01d84) (>2158) ThreadedClass …/JobHandler/JobHandler.cpp l:394 time: 4:00:00p (1336703771 s) thread: 0x2b0a3000 Rel: Y Got: Y
02 05/10/12 19:36:11.199 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.199 OL: (0xcf7ce4) (>2352) Lua LuaInterface.cpp l:1739 time: DL7:34:52p (79 s) thread: 0x2b9d7680 Rel: N Got: Y
02 05/10/12 19:36:11.200 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.200 OL: (0xc63a6c) (>2871) ThreadedClass …/JobHandler/JobHandler.cpp l:394 time: 4:00:00p (1336703771 s) thread: 0x2bbd7680 Rel: Y Got: Y
02 05/10/12 19:36:11.200 OL: (0xc63a6c) (>2876) ThreadedClass …/ZWave/ZWaveJobHandler.cpp l:777 time: DL7:35:04p (67 s) thread: 0x2b7d7680 Rel: N Got: Y
02 05/10/12 19:36:11.201 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.201 OL: (0xb01df4) (>2882) Variable Device_Basic.cpp l:446 time: 7:35:04p (67 s) thread: 0x2b7d7680 Rel: Y Got: Y
02 05/10/12 19:36:11.201 OL: (0xb01df4) (>2888) Variable Device_Basic.cpp l:446 time: 7:35:04p (67 s) thread: 0x2b7d7680 Rel: Y Got: Y
02 05/10/12 19:36:11.202 OL: (0xcf7ce4) (>2890) Lua LuaInterface.cpp l:1980 time: 7:35:04p (67 s) thread: 0x2b7d7680 Rel: N Got: N <0x2e3d7680>
02 05/10/12 19:36:11.202 finished check for exceptions <0x2e3d7680>
02 05/10/12 19:36:11.202 OL: (0xb033bc) (>3324) alarm AlarmManager.cpp l:109 time: 7:36:04p (7 s) thread: 0x2b7d7680 Rel: Y Got: Y <0x2e3d7680>
2012-05-10 19:36:11 - LuaUPnP Terminated with Exit Code: 137
2012-05-10 19:36:11 - LuaUPnP crash
01 2012-5-10 12:14:31 caught signal 6 <0x2c089680>
So basically I was not able to do anything with the unit. restore from abckup did not work, Repair did not work…
So I called the tech support. No luck
After 30min they asked me to open a ticket and we all know how long this takes…
Anyways… So I started thinking. 3 days ago I installed the ERGY Energy Plugin. I noticed that the system was a lot slower after the iinstall but did not think of this as a big issue.
Since I did not want to wait for couple of days and out of desperation I went ahead, deleted the ERGY plugin, removed the wattage info from the notes and bam… its working again like a charm…
My question is, has anyone observed this issue? Is anyone using ERGY? I am really getting kind of annoyed here. I am grateful Vera is working again but now I am unable to measure the energy usage… and there tech support soes not seem to know whats going on…
Flo >:( >:(
