Lua table to javascript array.
Just wanted to add a javascript tab to some work I am doing, what I have done is create a table with the data convert to string
luup.variable_set(ELK_SID, "TroubleReport",(table.concat(troubleList,",")), lug_device)
then at the javascript end I have dropped the string straight into an array.
trouble = new Array(troubleReportList);
Currently I only have one item in the list so can’t test and was hoping someone could tell me if this works with multiple entries?
John
I think it’s
trouble =  JSON.parse( "[" + troubleReportList + "]" )
in JavaScript as long as each member of troubleReportList is formatted like a JSON object. See this link: http://www.w3schools.com/json/json_eval.asp
watou
@watou
Thanks, went for “split” but will give this a try.
Cheers
John
