Lua parse failing
I have minimised my “run” code to the following to try and work out why I am getting parse failures.
Can someone help, I can’t see the issue?
[code]
for k, v in pairs(luup.devices) do
     local LowChild = 1
     if (k < LowChild) then
      LowChild = k
 </run>[/code]
The above code results in the following in the log file
01 02/06/11 9:57:09.149 LuImplementation::Parse can't parse xml /etc/cmh-ludl//I_Rain8net1.xml <0x400> 01 02/06/11 9:57:09.150 JobHandler_LuaUPnP::ParseAllImplementations failed to parse I_Rain8net1.xml <0x400>
Device files are in XML format.
Characters like “<” and “>” need to be escaped in any code that’s in a Device file, so they make well-formed XML files.
write “<” as “<”
write “>” as “>”
In your example, this “snippet” of the code becomes:
[code]
     local LowChild = 1
     if (k &lt; LowChild) then
      LowChild = k
 </run>[/code]
Thanks for clearing that up.
I was working on the premise that I did not need to worry about that between the tags.
Cheers
John
Yeah, that one bites everyone at some time or another. I started using an XML editor a few months back, which has helped a bunch, but I still make the mistake from time to time.
I learned to write my comparisons using greater-than instead of less-than. In XML it isn’t necessary to escape greater-than as > in normal text, so your Lua ends up looking normal.
In the new release version you’ll have the option to put the Lua code in a separate .lua file, so this won’t be a problem anymore.
BTW, I’d recommend to make it possible to put the files into a separate directory for each plugin.
It’s a good idea, we’ll surely consider implementing this.
