Hi Futzle - been playing around with the system for a while now (although still waiting for a new rs232 shorter cable to eradicate any issues caused by noise) and been using the alarm sensors in the house to trigger scenes using your wonderful plugins (combination/timer/virtual switch)
*quick note. firstly i would be happy to pay for the apps above. so if you take donations let me know so i can support your dev work.
my tests/experience has show or resulted the following issues/questions.
1.some times the lua startup takes longer than other times. i estimate it should take 20secs max. is this correct?
2.if partitions are armed (i.e. 1 & 2 out of 3) the lua startup doesnt seem to run correctly - it just freezes indefinitely when i press reload on the interface. if i disarm the partitions it re-activates
3. do pins 7 and 9 affect anything on the plugin and nx 584 (the manual says the are not operational) is that the case for the pluggin also?
4. is it possible to change a sensor type after it has been created? (ie. from motion to door)
thanks
