I just installed IT100 + Wiznet to my Power832/PC5015.
Set up Wiznet as server, local ip 192.168.0.220:5000, server ip 192.168.0.221:5000
Installed DSC plugin to my Vera 2 UI 5 through apps. Used ip 192.168.0.221:5000
Vera creates partion and zones but then I get Lua Failure Lua Failure.
Checked that plugin is set to IT100.
There should only be 1 IP address for the WIZnet, I’m not sure how you have two for it. My guess is that the IP Address in Vera is pointing to the wrong spot, but if you can provide a copy of that part of the log ([tt]/var/log/cmh/LuaUPnP.log[/tt]) I can tell for sure.
Where are you entering that? It should either be 0.0.0.0 and the port after it as 0 in the next box, or I think somebody else posted that they also got it working by substituting with the IP address with that of the WIZnet itself.
