I’m starting with a Vera Edge and I can’t get something basic. I’ve done a lot of testing and read hundreds of posts but I can’t find the solution.
The following code:
-- READ devices & WRITE total
local i
local v=0
local v0=0
for i=51,64,1 do
v0=luup.variable_get("urn:micasaverde-com:serviceId:EnergyMetering1", "Watts", i) -- read devices
if (v0 == nil or v0 == '') then
else
v=v+v0
v=math.floor(10*v+0.5)/10
luup.variable_set("urn:upnp-org:serviceId:VContainer1", "Variable1", v, 101) -- write on device #101
return true – of course
reads the power (Watts) of devices 51 to 64, adds it and writes it to Variable1 of device # 101 (multistring).
This code works in Lua test but it doesn’t work when I bring it into a scene. I have tried declaring it as a function and calling the function with luup.call_delay or luup_call_timer but I have not gotten it to work.
Can somebody help me?
Thank you very much in advance
