Vera is sending low battery notification when the device is still showing the battery at 80%
I have several of these sensors but the oldest one which is only about a year and a half is sending the alert for low battery. I changed the battery about two months ago and I am getting the alert again. Is there a place to change the percentage for when Vera sends the alert or is the device false reporting and false triggering.
Hello @Tim88
Please try unpairing your device and then pairing it again, this should fix it. Let me know if your issue persists after doing this.
