Hi
I have installed a LED strip and bulb (MI-LIGHT) Both were working fine and then i lost the connection to the bulb. LED strip works fine. I have un linked and re linked the bulb to a different group and also tried it on the same group as the strip. Works fine from iphone app but cant get it to work through Vera any more. I also deleted the bulb from vera and setup again.
any help would be appreciated.
cheers
Are you saying that, if you enroll the bulb and the LED strip on the same group, they both respond to the MiLight App but only the LED strip responds to the plugin? What type of bulb and LED controller are you using?
Yes that is exactly what I am saying. They were both working through the plugin and then one day it just stopped. Light is mi light series GU10 rgbw. I’m light series wifi controller
So I started from scratch reset the controller and vera plugin and all works ok.
Thankyou
