Losant IOT Platform
If you’d like to try some Node-Red type integrations and workflows but don’t want to spin up Node-Red, check out Losant: [url=https://www.losant.com/]https://www.losant.com/[/url]
You can actually do a lot with just the free tier. With MQTT, Webhooks, and HTTP support; you can easily tie together devices in and out of the ZWave landscape. Easy integration with AltUI via plugins such as MQTT, or even just http calls.
Granted not as feature rich as Node-Red, but if your needs are modest or you’re just starting out, it’s not bad at all.
I learned of Losant while poking around in the particle.io forums.
Cheerz --D
