Today, my vera DEVICES page is showing many devices with the default blue circle icon. all the window shields or temperature sensors have this default icon . the switch & dimmer are still with the good icon.
rebooted several time, any idea what could be wrong ?
( I did install yesterday the Google weather 1.51 plugin from @guessed ) but it seems to work fine so do not know if there could be a link
OK so here is the result. i installed Chrome and do not have the issue. conclusion
on Win8/IE10 , windowcovering device, holidayplugin device, google weather device do not show properly the icon in the device dashboard panel. instead we get the default blue gear icon. Cache clearing , Ctrl+F5 is not fixing the problem
on the same machine , at the same time and against the same vera but using chrome browser, all icons are displayed properly.
That explains ! thank you.
note that it seems the situation is degrading with Win8 and IE10 as I used to have WIn7 and IE9 and did not have this icon issue. it is also strange that this is only affecting some of the plugins not all.
