Saw some post regarding the Honeywell L5100 but after registering I’m not sure if this is the right forum for questions regarding the L5100.
Perhaps you should state what type of help you are looking for.
If you’re looking for help integrating this system with Vera, then you could be in the right place. Although, the Lock, Motion and Security Control section would likely be a categorically better place to post.
If you’re looking for help installing or getting the Honeywell L5100 to work in general, without pertaining specifically to Vera, then this is probably not the forum to seek help from.
Thanks for taking the time to respond. Looks like I’m not in the right place.
