Does anyone know of a z-wave enabled infrared thermometer which can read the temperature of a surface? I have a room with floor heating where there is no probe or room for a probe into the floor.
In addition to the floor heating there is a secondary heating unit which I already control with a z-wave enabled unit and this one provide the basic heat for the room. What I want is to let this secondary unit heat the room, but have a little bit of heat on in the floor for the feet. Now the heat from the secondary unit is forcing the thermostat on the floor heat to turn off all the time, leaving the floor cold.
Thanks for the suggested solution. I was hoping to find a one z-wave component which can do this.
Though; I wonder if there are a infrared temperature sensor which could be connected to ex a Qubino Thermostat. If the temperature sensor probe could be just replaced with a infrared sensor it would be nice.
How about just setting a minimum setting for the floor heating based on outside temperature. If it is cold outside you will want some floor heating. The room stat can allow the floor heating to increase but will not turn it off. Maybe use a high set on the room stat that also overrides the minimum setting if the room gets too warm.
The higher the outside temperature the lower the minimum floor temperature down to off.
