Login Issue
I cannot seem to login to ALTUI. I am using UI5 and followed the instructions for installation of the device. I am trying to login remotely to my Vera using https://vera-ui.strongcubedfitness.com/Veralogin.php. When prompted for user name and PW, assumed that I would use the same login as my MiCasaVerde credentials but no go. I’m assuming I’m missing something here.
this remote page is only for UI7. the way for UI5 is a bit more manual but fortunately you can then save the url it requires; it is explained in the readme and here
=> http://forum.micasaverde.com/index.php/topic,30310.msg225132.html#msg225132
Using VeraPlus, I am experiencing the same login problem. When I try to login with my VeraPlus password I get “Warning-Invalid Login-Try again” It does use the same password doesn’t it??? If not what does it use??
Same login and pwd. Maybe a special character problem ?
Hi
I’ve got the same issue now. Long time since I’ve been in there but need to do some remote work in the datamine plugin.
I use a password bank, and I tested it first on getvera/login which worked but at AltUI I dont get through.
Running UI7 version 1.7.2138.
Thanks.
