Hello
I’m using a SRT321 controller, and I would like to log and record the value of his temperature sensor sent to the Vera Plus UI7.
How can I do that ?
thank you !
Hello
How can I do that ?
thank you !
Look in this section of the forum at DataMine 2 and/or DataYours: http://forum.micasaverde.com/index.php/board,43.0.html
I prefer the DataYours solution with Grafana for viewing, but DataMine also works well. I’m also tinkering with using the InfluxDB for the data storage (on a Raspberry Pi).
Thank you for your answer.
Are they both working on VERA UI7 ?
Because Im struggling a bit to configure
I installed it, it added 1 module, but say me no data base.
I don’t know how I have to set the plug in.
DataYours works with AltUI which is a plugin that works with UI7. People have reported success with DataMine with UI7. Maybe you could post in that section of the forum with more details on the issues you have?
I use Datamine2 and my only complaint is the data channels and data are lost when I update the firmware. I will be looking at InfluxDB once I unpack my Pi3 iin my garage. No time at the moment.
