I just installed 18.8.10 dev and have the following issue. Log files save, however the rotating log saves as "LuaUPnP_startup.log.(1,2,3 etc) The actual startup log reverts to saving in “/etc/cmh-ludl/logs” also as “LuaUPnP_startup.log”
Here are my start-up params. There are no errors in the logs themselves.
[code]luup.attr_set (“openLuup.Historian.Directory”,“/media/historian/”)
local lfs = require “lfs”
local logs = “/media/logs/”
luup.attr_set (“openLuup.Logfile.Name”, logs … “LuaUPnP.log”)
luup.attr_set (“openLuup.Logfile.Name”, logs … “LuaUPnP_startup.log”)
– /var/log/cmh/ ensure it’s there for AltUI logs
– won’t work the first time it’s created
local altlog = logs … “altui”
lfs.link (altlog, “/var/log/cmh”, true) – true for symbolic link[/code]
The media folder is a mounted USB drive with logical subfolders.
