I just received a replacement dongle and made an update from 1.0.616 to the Luup version 1.0.979 to be able to backup the data in my old dongle. It all went well, but when I tested things it looks like the scripts I use to control my devices, which uses HTTP commands does not work anymore.
I tried to back off to version 1.0.608 which was the only old one I could find, but now I am stuck with Vera saying “Cannot retrieve user data.”. From here I cannot go anywhere…
So:
How do I get my Vera up and running with version 1.0.616 again? I have tried reset…
You can send a command to a device through Vera or through findvera.com secure service directly by using some URLs in your broswer. Here are some examples:
Many thanks for your help
I guess this will solve my scripting problem…but at the moment I cannot try it as my Vera is locked.
After restarting Vera it stops with the message “Cannot retrieve user data.” after the “Data loading” messages etc, and no matter which button I press there is a pop-up window saying “Please wait for data to load.”.
Is there anyway I can get back to where I can install 1.0.616 or 1.0.979 again?
