I’d like to have a lock screen for ImperiHome that allows control of everything but changing the house mode. Is this possible?
I can hide the individual sensors in the Flat Devices section but I want to have the app functional on a wall mounted tablet without unlocking but if you press house modes you need to enter a PIN code.
[quote=“Sammy2, post:1, topic:197662”]I’d like to have a lock screen for ImperiHome that allows control of everything but changing the house mode. Is this possible?
I can hide the individual sensors in the Flat Devices section but I want to have the app functional on a wall mounted tablet without unlocking but if you press house modes you need to enter a PIN code.[/quote]
Yes you can lock individual devices. I lock my fireplace (needs a finger print input, but could be pin or just a prompt) from turning on. I also lock my door locks with the same fingerprint. You can also lock settings and few other things.
[quote=“integlikewhoa”][quote=“Sammy2, post:1, topic:197662”]I’d like to have a lock screen for ImperiHome that allows control of everything but changing the house mode. Is this possible?
Yes you can lock individual devices. I lock my fireplace (needs a finger print input, but could be pin or just a prompt) from turning on. I also lock my door locks with the same fingerprint. You can also lock settings and few other things.[/quote]Where did I miss this? In the widget configuration?
I’m using $30 Fire HD 8’s that have no fingerprint sensor.
Thats why it says you should also lock your configuration in the notes posted there. I’ve not locked any of mine yet, but it makes sense…lock the tool then lock the ability to edit the tool.
Locking the configuration will prevent other users from messing it up too. It’d be nice to have different PIN’s for various users so only one has admin rights… ME!
