The scenes you create should be found under the ‘Automation’ tab. If you didn’t assign the scene to a room, then they’ll be at the top under ‘no room’.
I wonder if he is referring to the scenes created are the notifications? I heard that when creating notifications, they are a scene hidden. Never used the notifications in vera.
I have a similar problem. I created “Very low battery” notifications for 2 of my kwikset door locks and then I removed those notifications. In veralite both notifications are deleted but I see one of them showing up as active scene in HomeBuddy and AutHomation apps on my android phone.
By the way, does anyone know why the notifications are shown as scenes in HomeBuddy and AutHomation?
Since I do not use Vera’s notifications I can not tell you why they still show up in the apps and not in Vera. From my understanding the notifications are scenens, but MCV hides them from the user’s in plain site. They most likely are tagged with the scene attribute hence the reason showing up as a scene.
