I’m using a script that relies on https://sta1.mios.com/locator_json.php?username=xxxxxx.
Now it’s not working anymore. Is this locator service down? Or has it something to do with my Vera Lite upgrade to UI6?
(http://wiki.micasaverde.com/index.php/Luup_Protocol#Locating_the_MiOS_engine)
Thanks,
Bert
If you are on UI6 this URL will not work. It will only work with UI5. You will have to use a completely different URL in which it cab get very complex if not used on the local network due to the new authentication method.
Is there any documentation availible yet on how to do this?
Thanks.
This is not an easy task with the new MMS service. Depending how you use it, it will require multiple calls to authenticate and it is only valid for 24 hours. Here are some notes.
http://forum.micasaverde.com/index.php?topic=24942.0
