Local Backup
Hey @Sorin how can I create a local backup of my vera
I go to back up page in settings and click create backup, it is download to my download folder of my browser.
local backups can be restored to any controller of the same model as the HW key is not encrypted or synced to the backup. for some eason i can only do cloud backups
Hi Richie,
The backup files are not stored on your controller but in the cloud, so it’s tied to your account. To download a backup you’ll have to be logged in.
i need to restore a backup to a new controller y old one died every time i try it doesn’t work i get an error message
Finally figured this out myself today.
Added the following to contrab via root:
23 0 * * * curl -o - -m 30 ‘http://127.0.0.1:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:ZWaveNetwork1&action=BackupDongle&DeviceNum=1’ 2>&1
5 0 * * * /usr/bin/backup.sh 2>&1
In terms of the backup script, created the following:
root@MiOS_XXXXXXXX:/data/backup/archives/XXXXXXXX# cat /usr/bin/backup.sh
#!/bin/sh
dest_path=“/data/backup/archives”
backup_file=“/tmp/Backup_download.tgz” # Generated by /usr/bin/backup-store.sh
serial=“$(nvram get vera_serial)”
dest_path=“${dest_path}/${serial}”
dest_file=“ha-gateway-backup_${serial}$(cat /etc/cmh/version)$(date +%F).tgz”
sh /usr/bin/backup-store.sh D
mkdir -p “${dest_path}”
mv “${backup_file}” “${dest_path}/${dest_file}”
Of course, in my example I am using a USB stick for Vera local logging and have reused the 2nd partition mounted at ‘/data’.
The above should give you sufficient insight as to how to trigger both (a) a zwave network backup and (b) Vera device backup. Should my device fail, I can take the USB stick out and rebuild on a different piece of hardware. Nothing is stored in the Vera cloud in this fashion, but of course be cognizant that even a local backup is susceptible to failure if not regularly offloaded and backed up :wink:
Reused some ideas and code snippets from @rigpapa 's work. So just wanted to edit this post and provide credit where due.
