I just installed this dimmer into my Z-Wave network using a VeraPlus. The dimmer works fine except the dimming rate is not smooth like other dimmers that I have. The switch just seems to hop to the next dimming level. It’s not very aesthetically pleasing.
If I use the switch itself to dim the lights, then it is very smooth. When Vera issues a dim level command, the switch just “hops” to the final level.
I am sure there is a ramp speed or some setting that can be adjusted. I just have not found it.
