Hello all,
We’ve released a new LIVE update for Ezlo Linux firmware 2.0.33.2116.2 [production-147]
The highlights of this release are:
Devices bug fixing and improvements
Improvements and bugfixes of Ezlogic (Meshbots)
General fixes and improvements (SoftHub, cloud storage, child devices, and more)
The new LIVE update for Ezlo Linux firmware 2.0.33.2116.2 for Ezlo Plus and Ezlo Secure controllers contains:
Devices
Add support for the new Yale Lock product ID
Problems with the inclusion of Fortrezz Flood sensor FTS05
Zipato Z-Wave Remote PH-PSR03.US Problem with scenes
Add a 1 second delay to the Thermostat Mode Get command for AC301 in order to update the Mode correctly
Ezlogic/Meshbots
[Scenes] hub.scenes.edit couldn’t set any scene and notified no error
[Scenes][Date Node] isSunState/after/before: initial state for range events
[Scenes][Group Operations] Device Group entity: delete
[Scenes][Group Operations] Device Group entity: create
[Scenes][Date Node] isInterval: Arithmetic exception (core dumped) for isInterval with value 0s
[Scenes][Date Node] AND operator: allow isInterval with multiple isDate, isOnce conditions
General
Add the ability to delete a virtual device from UI
[Core] Handle room deletion for child devices with their own placement
[Core] Add ability to ignore child devices in the hub.device.room.set
[Virtual Devices] Make the test_plugin a part of the firmware update
[Core] Add device.parentRoom field
[CloudStorage] Incorrect params for storage_prepare_upload
[CloudStorage] Logs are uploaded without meta fields
[VirtualHub / SoftHub] ha-luad.log stops logging after trying to configure Mqtt Plugin
