I have just posted the data dump. It is 19:40 local time, and heer is the PLEG status:
Triggers
Name Description Last Trigger State
BedroomHot RFX Temp Master Bed temperature goes above 23 degrees 2013-08-23 19:01:46.334 true
BedroomVeryhot RFX Temp Master Bed temperature goes above 26 degrees 0 false
BedroomCold RFX Temp Master Bed temperature goes below 21 degrees 2013-08-22 22:35:52.400 false
OutsideHot RFX Temp Outside temperature goes above 19 degrees 2013-08-23 19:31:30.012 true
AC_Auto_ON MultiSwitch Switch 3 is turned on 2013-08-23 15:22:25.997 true
LWindowOpen Window Right is tripped 2013-08-23 01:50:51.690 false
RWindowOpen Window Left is tripped 2013-08-22 23:00:20.552 false
LWindowOpenArmed Window Right armed is tripped 0 false
RWindowOpenArmed Window Left armed is tripped 0 false
HeatingON MultiSwitch Switch 4 is turned on 2013-08-23 15:22:26.057 true
HotWaterON MultiSwitch Switch 5 is turned on 2013-08-23 15:22:26.155 true
AC_Test Test Multi Switch Switch 3 is turned on 2013-08-22 21:30:01.281 false
Away MultiSwitch Switch 7 is turned on 2013-08-23 19:34:29.323 true
Vacation MultiSwitch Switch 8 is turned on 2013-08-23 15:22:21.128 false
Schedules
Name Type Time Days Last Schedule
WeekdayOn1 Weekly 21:30:00 1,2,3,4,5 2013-08-22 21:30:00.102
WeekdayOff1 Weekly 05:00:00 1,2,3,4,5,6 2013-08-23 05:00:00.106
WeekendOn1 Weekly 22:00:00 6,7 2013-08-18 21:45:00.101
WeekendOff1 Weekly 07:20:00 1,6,7 2013-08-18 07:20:00.104
check_Window Weekly 21:20:00 1,2,3,4,5,6,7 2013-08-22 21:20:00.100
HWOnWD1 Weekly 04:45:00 1,2,3,4,5 2013-08-23 04:45:00.102
HWOffWD1 Weekly 05:35:00 1,2,3,4,5 2013-08-23 05:35:00.101
HWOnWE1 Weekly 05:50:00 6,7 0
HWOffWE1 Weekly 06:40:00 6,7 0
HWOn1 Weekly 16:30:00 1,2,3,4,5,6,7 2013-08-23 16:30:00.105
HWOff1 Weekly 16:50:00 1,2,3,4,5,6,7 2013-08-23 16:50:00.101
HeatWDOn Weekly 04:50:00 1,2,3,4,5 2013-08-23 04:50:00.106
HeatWDOff Weekly 22:20:00 1,2,3,4,5 2013-08-22 22:20:00.101
HeatWEOn Weekly 06:45:00 6,7 0
HeatWEOff Weekly 23:00:00 6,7 0
Device Properties
Name Device Name Device Variable Last Change Value
DOW DOW 2013-08-23 00:00:00.101 6
WE Weekend 2013-08-19 00:00:00.136 0
Conditions
Name Expression Last True State
Window BedroomHot and AC_Auto_ON and (ACWDIsOn or ACWEIsOn) and (NOT OutsideHot) and check_Window and NOT WindowOpen and NOT Vacation 2013-08-18 07:07:23.653 false
CloseWindow BedroomHot and AC_Auto_ON and WindowOpen and check_Window and OutsideHot and NOT Vacation 2013-08-21 21:20:00.158 false
WindowOpen LWindowOpen or RWindowOpen 2013-08-22 23:00:13.581 false
ACmanualHigh BedroomVeryHot and (21:42:00;NOW) and NOT Vacation 0 false
ACWDIsOn (WeekdayOff1; WeekdayOn1) and WE==0 2013-08-22 21:30:00.115 false
ACWEIsOn (WeekendOff1; WeekendOn1) and WE==1 0 false
ACWDIsOff (WeekdayOn1; WeekdayOff1) 2013-08-23 05:00:00.134 true
ACWEIsOff (WeekendOn1; WeekendOff1) 0 false
AC_On BedroomHot and AC_Auto_ON and (ACWDIsOn or ACWEIsOn) and NOT WindowOpen 2013-08-22 21:30:00.190 false
AC_Off (BedroomCold and (AC_On; Now > 15:00)) or ACWDIsOff or ACWEIsOff or (NOT AC_Auto_ON) or WindowOpen 2013-08-22 23:00:13.597 true
HWOn (HWOnWD1 or HWOnWE1 or HWOn1) and HotWaterON 2013-08-23 16:30:00.133 false
HWOff (HWOffWD1 or HWOffWE1 or HWOff1) or (NOT HotWaterON) 2013-08-23 16:50:00.133 false
HeatON ((HeatWDOff; HeatWDOn) or (HeatWEOff; HeatWEOn)) and HeatingON and (NOT Away) 2013-08-23 19:34:26.770 false
HeatOff (HeatWDOn; HeatWDOff) or (HeatWEOn; HeatWEOff) or (NOT HeatingON) or Away 2013-08-23 15:17:09.847 true
_ACtestON WeekdayOn1 or WeekendOn1 2013-08-22 21:30:01.276 false
_ACtestOFF WeekdayOff1 or WeekendOff1 2013-08-23 05:00:00.159 false
AC_On_test BedroomHot and AC_Auto_ON and _ACtestON and NOT WindowOpen 0 false
AC_Off_test (BedroomCold and (AC_On_test; Now > 15:00)) or _ACtestOFF or (NOT AC_Auto_ON) or WindowOpen 2013-08-23 15:22:20.995 false
AC_On_test2 BedroomHot and AC_Auto_ON and AC_Test and NOT WindowOpen 2013-08-22 21:30:01.323 false
HeatOntest (HeatWDOff; HeatWDOn) 0 false
Htest Away 2013-08-23 19:34:29.372 true
Actions
Actions for Condition: AC_Off
Device Action Arguments
Air Condition SetModeTarget NewModeTarget=Off
Actions for Condition: Window
Push Notification SendProwlNotification Event=Open Bedroom Description=Window Priority=1 URL=
HVAC RunScene SceneNameOrNumber=59
Actions for Condition: ACmanualHigh
Push Notification SendProwlNotification Event=Turn On AC High Description=Bedroom very hot Priority=1 URL=
HVAC RunScene SceneNameOrNumber=64
Actions for Condition: AC_On
Air Condition SetModeTarget NewModeTarget=CoolOn
Push Notification SendProwlNotification Event=AC Description=AC is ON Priority=1 URL=
Actions for Condition: HWOn
Test Multi Switch SetStatus1 newStatus1=1
Hot Water SetModeTarget NewModeTarget=HeatOn
Actions for Condition: HWOff
Test Multi Switch SetStatus1 newStatus1=0
Hot Water SetModeTarget NewModeTarget=Off
Actions for Condition: AC_On_test
Test Multi Switch SetStatus4 newStatus4=1
Actions for Condition: AC_Off_test
Test Multi Switch SetStatus4 newStatus4=0
Actions for Condition: CloseWindow
Push Notification SendProwlNotification Event=test Description=close window Priority= URL=
HVAC RunScene SceneNameOrNumber=71
Actions for Condition: HeatON
Test Multi Switch SetStatus2 newStatus2=1
HVAC RunScene SceneNameOrNumber=74
Actions for Condition: HeatOff
Test Multi Switch SetStatus2 newStatus2=0
HVAC RunScene SceneNameOrNumber=73
Test Multi Switch SetStatus7 newStatus7=-1
Actions for Condition: _ACtestON
Test Multi Switch SetStatus3 newStatus3=1
Actions for Condition: _ACtestOFF
Test Multi Switch SetStatus3 newStatus3=0
Actions for Condition: Htest
Test Multi Switch SetStatus5 newStatus5=-1
Actions for Condition: HeatOntest
Test Multi Switch SetStatus8 newStatus8=-1
