Linux Firmware v2.0.79.3078.10 [production-204] for Ezlo Plus, Ezlo Secure
New
  • Integrated Jasco UltraPro ZW-4008 In-Wall Smart Switch with ZWave.
  • Aeotec Home Energy Meter Gen5 ZW095 now displays individual clamp measurements in Ezlo UI for improved energy monitoring.
  • Support added for alarm sound selection on Savvi siren.
  • Savvi KeyFob now functions as a 4 button remote, enabling full integration.
  • Implemented the alarmed state for hubs on Ezlo Protect.
  • Introduced system image creation alongside the SD-card image in a bundle.
  • Added NMA client reconnect metrics for improved robustness.
  • Introduced graceful reconnect to NMA for Linux firmware as part of robustness enhancements.
  • Reduced firmware image size for E550 updates to minimize cellular data usage and ensure downloads resume after connectivity drops.
  • Implemented a mechanism for working with webhooks in myQ integration.
Fixes & Improvements
  • Resolved camera issues in ONVIF integration.
  • Backups now generate correctly every 24 hours for all hubs.
  • Zigbee device pairing issue resolved for Ezlo Plus hubs on prod194 firmware.
  • Z-Wave OTA update issue for the Ezlo Thermostat has been resolved.
  • Fixed issue with scenes manager experiencing frequent service restarts.
  • Silent SOS alarm no longer activates the controller’s siren.
  • Fixed an issue where the hub.offline.cloud.data.update.progress incorrectly finished with a ‘Deploying failed’ status.
  • Fixed an issue where the TCDS data from the hub was not updating correctly, causing notifications to use outdated s3_id.
  • The entry delay countdown now correctly displays the alarmed object in hub.modes.get v3.
  • Meshbots now avoid unnecessary syncs when broadcasts lack trigger fields, improving efficiency.
  • Backup restoration no longer results in empty data following a factory reset.
  • Increased cloud storage connection timeout to 90 seconds to improve file upload reliability.
  • Fixed an issue where the controller fails to connect to Wi-Fi using the correct password after an incorrect password attempt.
  • Updated local mode certificates for component tests to ensure valid HTTPS/WSS server access.
  • Controller reboot behavior updated to require a 10+ seconds press of the speaker button instead of 2+ seconds.
  • Restoral event direct signal delay now matches the armed and tripped signal delay.
  • Alias for the 101 MEDICAL PENDANT code has been added to specified sensor groups.
Thank you for your continued support, and please let us know if you encounter any issues or have feedback!
Release notes link:
