Linksys IP Camera WVC54GCA - No Picture & can't remove /install plugin
Using UI4 with Vera-1 and unable to make Linksys WVC54GCA to show snapshots or stream pictures. Tried adding camera with ip address in the URL space with " http://192.168.81.200:80/img/snapshot.cgi" no results. Then tried install Mios generic IP camera plugin from Market place. but the plugin fails to install with message " installation failed, reason: service not active" though I have logged into Mios with username and password. I get the streaming pictures in standalone apps like ‘Home Buddy’, and also in camera IP address page but not in UI4 or MIOS app ‘Vera Mobile’. So I tried to to uninstall the camera in UI4 : Devices list, but the camera does not get removed with error message “Command failed : invalid plugin” Can anyone suggest a work around this issue,
I have one of those on UI5 and it is set the following…
Settings:
URL-> img/snapshot.cgi?size=640x480&quality=4
user name → use yours
password-> use yours
IP-> use yours
Advanced:
device_type → urn:schemas-upnp-org:device:DigitalSecurityCamera:1
device_file-> D_DigitalSecurityCamera1.xml
DirectStreamingURL-> /img/video.mjpeg
Not sure if that will help for UI4
I cut & pasted the settings given but didn’t work. It is trying to load LUUP camera plugin#5 every time I make a change in camera and click the red ‘SAVE’ button but everytime it fails to load. I also don’t see the installed plugin icon under ‘Mios Market’. I tried deleting the camera but it refuses to get deleted with a message ‘invalid plugin’. Even if I type the (IP addrees)/img/snapshot.cgi in a browser the picture snaps out but not with Vera-1 or 2. Thanks a lot for giving me the settings.
