I have a configured vera3, and am about to add a veralite so I can better control some distant Zwave devices.
Given my topology, it would actually work best if I moved the Vera3, which currently has about 10 zwave devices linked to it, to the remote location and put the veralite in it’s place. If i do this, though, the vera3 will be out of range from the current z-wave devices.
- Should I unpair all zwave devices ,then re-pair them to the veralite?
1A) Can I restore the vera3 zwave device backup to the veralite to avoid re-pairing them all again? - Do both Veras use the same MIOS credentials, or do you use two different logins?
Thanks!
