Linear WDZ500-1 pairing problems
I just upgraded to a VeraPlus and Vera support moved all of my config over from my UI5 Vera Lite. Everything is pretty much working now, but some of my Z-wave devices said Can’t Detect Device, or configure device failed. I deleted 2 of the Zwave dimmers, and tried to readd them. One of them added just fine. The other one, I cannot get it to add no matter what I do. I’ve tried the unpair procedure as well, and it’s just not working.
Is there something I need to reset in the switch to get it to pair?
Double tap the switch when unpairing.
I tried that. I also tried plugging the Vera in right next to it and using the select/sync buttons to put it into Include mode. Nothing.
