Linear WD500Z-1
I bought the wall switch and installed it. The switch itself was able to turn the light on and off without a problem. I tried to pair it to my vera device. I had a lot of trouble with it, but it seems that it finally worked. Not for long though.
Vera says it is configured. I can turn it on and off (at least that?s what it says in vera), but the actual light does not come on or off. I then tried to use the actual switch but it does not turn on or off the light. The little green light comes on when I press to turn off and comes on when I press to turn on the light. But the actual light does not turn on or off. It worked fine initially. Can’t have it all I guess.
Any help ?
Thanks.
I would suggest that if it won’t control the light locally then there is a problem with the device itself.
Try checking the wiring first and power it off and on again.
Then un-pair re-pair.
If that doesnt work it could be toast.
