I think I’ve hit the load limit on a Linear WD500Z-1 - it’s running very hot, with 4 ceiling fixtures running off it.
It’s in a 4-gang box, so I can try switching it out with one of its slaves that is in a smaller box to try to improve cooling - but I’m curious, anybody know of a higher-capacity Linear that works as a master with the Linear WT00Z-1 slaves?
Thanks!
Paul
[quote=“PaulFortier, post:1, topic:187342”]I think I’ve hit the load limit on a Linear WD500Z-1[/quote]Why don’t you know with certainty? Add the wattage of every bulb on the circuit, it must not exceed 500 watts and should probably not exceed 400 watts.
it's running very hot, with 4 ceiling fixtures running off it.
Very hot is very bad.
It's in a 4-gang box, so I can try switching it out with one of its slaves that is in a smaller box to try to improve cooling - but I'm curious, anybody know of a higher-capacity Linear that works as a master with the Linear WT00Z-1 slaves?
I don't think that Linear makes a higher wattage dimmer. But Leviton makes 1000 watt dimmers. The Linear "slaves" as you call them are one button scene controllers. You should be able to associate them with the Leviton dimmers just fine.
Leviton DZMX1-1LZ Decora Z-Wave Controls Scene Capable Universal Dimmer 1,000 watt incandescent but 450 watt LED. Does NOT support Instant Status.
Leviton VRMX1-1LZ 1000W Vizia RF ZWave Universal Magnetic Low Voltage Dimmer 1,000 watt incandescent but 450 watt LED. Supports Instant Status.
Leviton VRI10-1LZ Vizia RF + 1000W Incandescent Scene Capable Dimmer 1,000 watt incandescent. Supports Instant Status.
[url=http://Paul
[/quote]
