These switches use a scene controller remote, the Linear WT00Z-1/Evolve LTM-5 that is powered, but not directly wired to the WD500Z-12 master, for n-way circuits. (See diagram Evolve 3-Way-1.png below.) The Linear Evolve switches cannot be combined with standard electrical switches on the same circuit.
So, if I use the Aeon Lab Switch (not dimmable illuminator) on existing dimmable switch, I should be able to use the zwave function to switch on and off while keeping the dimming function manual on the wall switch itself?
Also, would this be instant as I’m some delays when turning on and off manually with the GE/JASCO units.
This could be done with the Aeon Labs microswitch or any relay switch on the line side of the circuit. The Z-Wave switch energizes the circuit and the standard triac dimmers dim the lights.
However, using the Aeon Labs microswitch in this scenario would not allow you local On/Off control. You would have only Z-Wave On/Off control, unless you added yet another local switch to control the microswitch. Conversely, if you use microswitch dimmers with momentary switches for locally controlling the microswitch, you will have On/Off and dimming control both locally and via Z-Wave commands.
Also, would this be instant as I'm some delays when turning on and off manually with the GE/JASCO units.
Z-Wave commands from Vera to any device, including your GE/Jasco switches, should execute in a second or less. My Jasco switches respond to On/Off commands from the Vera GUI in 100-200 milliseconds. If you are experiencing multi-second delays it is most likely due to signal quality or routing issues. The problems are solved by adding more nodes.
