I have just purchased some linear WADWAZ-1 door sensors. I am sure this is rather simple but I cannot figure it out. I have installed it on a door. When the door is opened it triggers the lights on in the kitchen. When I close the door the lights turn off. I want the lights to stay on until I manually turn them off. I just set up a simple scene in UI15 to trigger the light on. WOuld appreciate any help.
I fixed the problem. I unassigned the sensor. Took the battery out and back in. Reassigned it to Vera and now it works properly
How did you get this to pair to the vera? I can’t get these to work on my Vera3
