So I have Linear PD300Z-2 Lamp Dimmer Module and everything is connected properly. I’m on my Vera Profile and I click the on/off switch for the light in the profile, but nothing happens yet it says “Success! Transmit was OK”
Is there some sort of issue with the Linear module and Vera? I also have a Philips Hue system working in my house, but I took the Hue light bulb out of this particular lamp I’m trying to control with Vera and replaced it with a standard light bulb. Could the Philips Hue system be interfering in some way?
