I am trying to understand how to control my WD500 dimmer with my WT00Z. So far I have tried adding group 1, and pointing to the wd500z, then going into the wd500z and adding group 1 and pointing it to the wt00z. It doesn’t seem to work that way. Any suggestions? I have hunted high and low, but I don’t see any concrete instructions.
*using UI7
Linear WD500Z as a Master
Linear WT00Z as a Slave
The association configuration is performed on the WT00Z-1 only.
Add group 1 and select the WD500Z-1.
Make sure that the node configures properly. The “Currently” field on the WT00Z-1 will show the node ID of the WD500Z-1 when it is properly configured.
