I have been working on custom software to use for wall mounted android devices to control my home from different key points through out the house and come across a problem with all my Linear dimmers and wanted to know if any one has had similar problems.
I know the devices don’t support instant status, but the devices are not being polled or updated for hours at a time. I’ve gone into the setting and tried to set the polling for devices to as low as possible, tried debugging a single switch and setting just that ones polling to be as low as possible, but they will not get updated in the vera for hours after a dim level has been set.
Here’s the perplexing part…
I also have several GE on/off switches that when switched almost immediately update in the UI. Even more confusing is if I double tap on/off on the Linear dimmers they update almost immediately (within about 1 second, the same as the GE switches). From reading through the forum I have learned that even though the manual for the Linear switches say they support associations for groups 2-4, they do not. Further I have inspected the associations and can confirm there is no association groups which make this happen. Does anyone know what is going on? How can I make the updating happen sooner? I wouldn’t even mind if the update happens 10 seconds later, but hours later (from testing it seems to be right around 3 hours), is not going to work. I have tried removing all plugins, and extra devices (secondary controller) to keep it down to the essentials, but the updates still take hours. I’m running UI7, latest firmware on the vera edge.
Thanks ahead of time for any help.
