Count me in!
Live in Quebec and would gladly buy at least 10 units!
Benoit
Count me in!
Benoit
me too, i’m interrested. I need 12 line voltage thermostat… minimum.
Tell me if you want some testers.
thanks
Hey,
I’m in NB, really interested in this product since I have the same problem everyone on this thread seems to have. Either ZWave or Zigbee does the thing for me. Hope to hear back from you.
[quote=“Les F, post:33, topic:170332”]Back onto fitting an Aube and a zwave tstat… trying to get an idea of where to stash the Aube in my setup. I use these style heaters.
They look like a long triangular wedge up near the ceiling. The only room is on the end for some wire nuts so relay needs to be external. I don’t want to put some box with a relay hanging off it next to the heater. Any suggestions? The only thing I have come up with is some kind of in wall electrical box to at least hide the bulk of the wiring/relay. And of course if the relay is in a box, I assume you shouldn’t be mixing 24volt next to 220v in the same confined space (at least not without some kind of separation)
The best solution I have found is something like this:
http://tinyurl.com/cbj55x9
Providing you have the room can the device be mounted next to the breaker panel
Any other ideas?[/quote]
Hey guys, since this conversation spun off topic (well, not really, but I wasn’t the OP) I have started a dedicated thread here
http://forum.micasaverde.com/index.php/topic,23401.0.html
Care to follow along ?
Well, it’s just right that I finish where this started…
A long-awaited solution to baseboard heating has arrived : it’s called Caleo and it’s now in a crowdfunding effort to support it’s launch later this year. Check it out, share your thoughts !
[url=https://www.kickstarter.com/projects/casa/caleo-the-line-voltage-smart-thermostat]
https://www.kickstarter.com/projects/casa/caleo-the-line-voltage-smart-thermostat[/url]
[quote=“T1000, post:66, topic:170332”]Well, it’s just right that I finish where this started…
https://www.kickstarter.com/projects/casa/caleo-the-line-voltage-smart-thermostat[/url][/quote]
I’ve been looking for years, Thank you / Merci
One more “THE MANSION + 4” on the pledge list is now gone.
