Hey Rex, I would like to build some MiCasaVerde automation in my home, does the LimitlessLED plugin work with with both the Black hub, and the Green/White hub?
i.e. Mi Casa Verde VeraLite Home Controller, White and Green vs. Mi Casa Verde VeraLite Home Controller black model.
what is the age difference between these two controllers? can they both run the same software updates?
The direct access light bulb 2.4Ghz RF commands have now been fully documented on the www.limitlessled.com/dev webpage. what are the chances that this plugin can hit up the registers of a 2.4Ghz transceiver inside a VeraLite Home Controller to talk directly to unlimited groups of bulbs?
-Hamish.
