Hello, I have a Hue with Althue installed I have noticed that the lights(and plugs) seem to turn them selves off over night, I turned on notification last night and it happened at 01:00 this morning
I dont have any scenes in vera or on the hue to do this, any ideas what might be causing this?
also in the Althue device there is a tab called Hue Scenes and when you click the tab it displays a lot of “scenes” with an id , according to the installation doc you can use these to run a scene in Vera BUT where are they in the Hue bridge they dont appear anywhere so I want to delete them in case they are running and turning things off
