Hi, I have an alarm keypad I would like to use together with vera and rfxtrx.
It has 3 options Away Arm, Stay Arm and Disarm. Rfxtrx is creating a door sensor named “RFX Door D/A9070”.
So far ok. (I can use the door sensor when tripped to run a scene). Problem is all three buttons is tripping the door sensor.
I checked all buttons in RFXmngr and received this:
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 6
Code = A90701 decimal:11077377
S1- S24 = 1010 1001 0000 0111 0000 0001
Pulse = 366 usec
Signal level = 4 -88dBm
subtype = PT2262
Sequence nbr = 7
Code = A90702 decimal:11077378
S1- S24 = 1010 1001 0000 0111 0000 0010
Pulse = 361 usec
subtype = PT2262
Sequence nbr = 11
Code = A90704 decimal:11077380
S1- S24 = 1010 1001 0000 0111 0000 0100
Pulse = 361 usec
It looks like the rfxtrx plugin is missing the last character in the Code line: ex. A90701 is picked up as A9070 by the plugin. Is there anything I can change in the plugin to get the right codes so that every button is creating its own device?
