Picked up a pack of 4 LIDL sockets (Silvercrest) 284795 model number euro sockets, anyone know if these can work with Vera rfxtrx plugin ? they are 433 mhz but no idea of protocol etc. thanks in advance.
The RFXtrx user guide lists two Silvercrest products that work using the Lighting4 or Lighting4 + AC protocols. I couldn’t find out what either of the two listed products are exactly besides being listed under Appliance modules, dimmers, relays, LED controllers. I also couldn’t find any information online about any of these products. I suggest that you try connecting the RFXtrx transceiver to you PC and use RFXmngr to try to operate these sockets.
Silvercrest 284705 can be used with the latest RFXtrx433E Ext2 firmware.
Enable Lighting4 + AC and the remote is received as Lighting5 - Kangtai/Cotech
You can check this with RFXmngr on a Windows system.
I don’t know if this type is supported by the VERA plug-in.
